I need to replace the fork seals on my zx1100a1 and plan to make a tool for holding the inner while I remove the bottom fork bolt. I tried to remove it before loosening the top fork nut which usually works.......unfortunately the spring force just wasn't enough to hold it.......anyone know what size nut I need to weld onto a steel bar to hold on the inside ??
Ta in advance folks
Gpz1100 forks - size of nut I need for holding tool
Users browsing this forum: Gus and 122 guests
