Fitting Ikon shocks
sprint
Fitting Ikon shocks
#1 PostAuthor: sprint » Tue Jun 02, 2015 6:31 pm
The Ikon shocks supplied for the 900's have an offset lower eye lugs? Does that not mean that you have to pack the top eye out by a similar amount?
No relevant fitting instructions are provided or anything to offset the top lug or do you just fit with the lop lug eye up against the frame as the original units were?
Logic tends to say that if the bottom is offset the same needs to be done to the top or they are not going to be fitted parallel?
I take it they are offset because the shocks are wider that the std ones?
Chris Riv
#2 PostAuthor: Chris Riv » Tue Jun 02, 2015 7:17 pm
Just fit them as they are. You cant space the bottom mount because of the design so if the damper eye is wider at the top, the whole damper moves out away from the frame hence the offset bottom eye, hope that helps.
Cheers, Chris
jimmock
#3 PostAuthor: jimmock » Tue Jun 02, 2015 7:20 pm
Fuckin' 'ell Guyz.
That sounds complicated!!! :kod
Jimmock. :wnkr
I hate people I don't like !
sprint
#4 PostAuthor: sprint » Wed Jun 03, 2015 8:27 am
Thanks for the reply
