K1 LTD Forks
Farmer
K1 LTD Forks
#1 PostAuthor: Farmer » Mon Jun 08, 2015 6:10 pm
After having my not so local bike shop do the repairs for the mot they renewed the fork seals and oil, I gave them some 15w oil, but on collection they had put in 10w, now after a few miles I am finding the forks are bottoming out all the time, would increasing the thickness of oil be enough ?, when I had my Sportster I put a socket in the top to preload it more.
What's everyone else doing ?. :D
1981 KZ1000 K1 LTD
Farm Boy with an O Level in Metalwork and not much else.
Everything in Sussex is a She, Except Tom Cat and She`s a He.
#2 PostAuthor: Pigford » Mon Jun 08, 2015 6:39 pm
Older bikes did have heavier oil - and it did effect the damping characteristics.
The spring rate is different to oil damping, but a heavier oil may well help. You can even get clever and blend oils to fine tune :lol:
My Triumph Speed Twin is supposed to have 20W oil in the forks (190ml each) but lots of people use 30W coz the front end is a bit soft. The level also has some effect.
#3 PostAuthor: z1bman » Mon Jun 08, 2015 6:48 pm
10w is the standard fork oil spec you will probably find they have put the wrong quantity in it shouldnt bottom out even with 10w oil in them
fork oil quantity 351cc + or - 4cc
Farmer
#4 PostAuthor: Farmer » Tue Jun 09, 2015 9:24 am
Ok thanks Guyz, I will check the level, I remember my 550 ltd was a bit soft.
1981 KZ1000 K1 LTD
Farmer
#5 PostAuthor: Farmer » Tue Jun 09, 2015 12:27 pm
I rang Z power and they put me in touch with Hagon and now a set of progressive springs are winging there way to me £84 a set.
1981 KZ1000 K1 LTD
