FORK LEG .WELDING.
ColSZ1B
FORK LEG .WELDING.
#1 PostAuthor: ColSZ1B » Thu Jun 25, 2015 9:22 pm
1975.Z1B.ONE OF MY FORK LEG MUDGUARD LUGS IS FRACTURED/PIECE MISSING.WELD OR REPLACE??? ANY HELP GREATLY APPRECIATED.CHEERS . COLIN.
steve452
#2 PostAuthor: steve452 » Thu Jun 25, 2015 10:57 pm
I have exactly the same problem. Is this common with Z1's?
Z1-B, 360bhp ZX1000NGF
Garn 1
#3 PostAuthor: Garn 1 » Fri Jun 26, 2015 2:54 am
I have often had them welded.
Can't remember if they had a 8mm helicoil in them as standard.. check!
It is common problem for these Z1 fork legs to crack and break-out at these front mudguard attachment points, as this guard acts as a fork brace.
If you have ever riden a Z without a guard you would know. Even a plastic guard is not strong enough to tie these fork-legs together.
RegardZ.
#4 PostAuthor: Pigford » Fri Jun 26, 2015 8:51 am
BEWARE - there is a possibilty the alloy leg may distort - then be useless :?:
jimmock
#5 PostAuthor: jimmock » Fri Jun 26, 2015 12:32 pm
Big K modified them early on from the early 72 Z1 type due to this weak defect.
Obviously they were still a slightly less weaker area.
Jimmock. :wnkr
I hate people I don't like !
