2000 r6 forks
sled
2000 r6 forks
#1 PostAuthor: sled » Fri Jun 26, 2015 9:46 pm
G'day
I have a set of 2000 r6 forks I am wondering if anyone has used them on their z900. I am building a custom just want to see if this is an ok starting point since I have the forks and wheels?
Any help is appreciated
Cheers Jason
garyd
#2 PostAuthor: garyd » Sat Jun 27, 2015 6:09 am
Can't see any reason why they shouldn't be O.K.
Obviously the length has to be taken into consideration and have you checked the springs are O.K. for the weight of the kawasaki?
sled
#3 PostAuthor: sled » Sat Jun 27, 2015 9:18 am
garyd wrote:Can't see any reason why they shouldn't be O.K.
Thanks for the reply
The early r6 forks measure 760mm centre of axel to top of fork leg unloaded the standard forks on my A4 measure 765 loaded. I don't know how this stacks up to other common swaps out there. I haven't seen any r6 fork swaps so I question if it is a good option.
Good point re weight I'll do some more research
Any comments on fork length ?
#4 PostAuthor: Al » Sat Jun 27, 2015 10:05 am
Standard spring rate for 2000 R6 looks like .760 kg/mm
http://racetech.com/ProductSearch/2/Yam ... /1999-2002
Bike weight for same year is 197 kg / 433 lbs
http://www.motorcyclespecs.co.za/model/ ... 6%2000.htm
Standard spring rate for Z1 900 not listed but should be around 0.6 to 0.7 kg/mm at a guess!!!!!
Weight of Z900 248 kg / 548 lbs
http://www.motorcyclespecs.co.za/model/ ... 0%2076.htm
It looks like you may end up with slightly reduced front travel with approx 50lbs more weight on the front than was originally intended for those forks..
sled
#5 PostAuthor: sled » Mon Jun 29, 2015 11:05 am
Ok thanks for the replies they don't seem a common swap which makes me think maybe sell and get something else
ADE
#6 PostAuthor: ADE » Mon Jun 29, 2015 11:20 am
You could get a new shaft machined on your R6 yokes. I had one machined to fit on the bottom yoke off a ZX9R to suit standard headstock bearings.
Cheers Ade
Users browsing this forum: No registered users and 108 guests
