rough running
wayno
rough running
#1 PostAuthor: wayno » Wed Jul 01, 2015 1:08 am
here goes, rebuilt my a4 over the last couple years, got it running, sounds lovely ticking over about 1k revs. revs nicely on the drive but when out on the road it struggles to pull away and does get slightly better when it warms up, if accelerating it is rough, sounds like its missing. during the build it had new rings, cam chain etc, dyna s ignition, it had green dyna coils which I changed to try and solve it, carbs stripped cleaned and rebuilt, new rubbers to head and airbox. I think it may be fuel related as the inline filters struggle to fill up when fuel tap is turned on, checked the breather ( same when cap open). If the tap disconnected from the carb and turned on it gets a good flow, seems to be only when connected to the carbs!! pulled the tap of and there was some crap around the reserve pipe so cleaned that and swilled the tank but still the same. got the wired George mod also.
any ideas?
wayne.
Chris Riv
#2 PostAuthor: Chris Riv » Wed Jul 01, 2015 6:38 am
Hello, Id be inclined to try it without the inline filters first because its an easy thing to eliminate. Try riding into a misfire & cutting the engine, coast to a halt & look at the plugs to see if its weak on all 4 cylinders equally (prob fuel starvation) or if its a 1/4 or 2/3 related issue ie an ignition issue.
Cheers, Chris
Garn 1
#3 PostAuthor: Garn 1 » Wed Jul 01, 2015 10:12 am
Wayno, just thought I'd mention a problem I once had. Fuel flowed freely from the pet-cock, however, when I put the tube back on the pet-cock the inner part of the rubber tube doubled-back on itself, hence, restricting the flow.
Another item may be stale fuel.... they don't last long these days.
Another thing may be slightly bent valve(s)... Give her a compression test with throttle open. It can easily happen during a rebuild!
RegardZ.
wayno
#4 PostAuthor: wayno » Wed Jul 01, 2015 10:32 am
i have one of these auxillary tanks so will give it a go with this hanging around my neck with no inline filters first.
http://www.ebay.co.uk/itm/Auxiliary-Fue ... 5af13e94d7
PAULJAC47
#5 PostAuthor: PAULJAC47 » Wed Jul 01, 2015 2:51 pm
I Like the idea of riding with one o them round yer neck be interesting if plod pulls you :lol: good luck though....
saxon46
#6 PostAuthor: saxon46 » Thu Jul 02, 2015 7:18 pm
sounds like carbs to me my old j was running rough,couldn't put my finger on it......put dyna s ignition/coils on it........borrowed a set of carbs ran great,got some replacements from the states...now running loads better revs out.....still not perfect,
I would see if anyone will lend you a set of carbs
mark ......english lad in wales....where men are men and sheep are scared !!!!!
wayno
#7 PostAuthor: wayno » Thu Jul 02, 2015 9:52 pm
saxon46 wrote:sounds like carbs to me my old j was running rough,couldn't put my finger on it......put dyna s ignition/coils on it........borrowed a set of carbs ran great,got some replacements from the states...now running loads better revs out.....still not perfect,
The cars were supposedly rebuilt with new kits but a mate suspects needle jet doesn't look right, there is a mark of some sort, maybe pitting, can I get the needle jets separately or only in full kits?
#8 PostAuthor: ZedHead » Fri Jul 03, 2015 5:29 am
Agree with everything that has been said already plus check you have good 12 volts at coils.
