Fitting Z1B Tail and Side Panels
Mark O'Shea
#1 PostAuthor: Mark O'Shea » Tue Jul 07, 2015 9:55 pm
Hi All,
Can anyone let me know if it is possible to fit a Z1B Tail piece and Side panels to the later Z900 A4, hopefully with little or no mods required.
Many thanks,
Mark.
000zeds
#2 PostAuthor: 000zeds » Tue Jul 07, 2015 10:47 pm
Tail piece will fit easily but you will need the oval tail light + bracket but the side panels will not fit :!:
Zeds-R-Us
jimmock
#3 PostAuthor: jimmock » Wed Jul 08, 2015 1:46 am
twozeds wrote:Tail piece will fit easily but you will need the oval tail light + bracket but the side panels will not fit :!:
Agreed.
I know of Guyz that have modified the frame to take the side panels.
Jimmock. :wnkr
I hate people I don't like !
garyd
#4 PostAuthor: garyd » Wed Jul 08, 2015 8:00 am
The top two mounting points for the side panels are about right.
It's the lower one that needs to be moved.
Garn 1
#5 PostAuthor: Garn 1 » Wed Jul 08, 2015 10:25 am
garyd wrote:The top two mounting points for the side panels are about right.
You do get into trouble around one of the top ones at the seat key-lock.
You might be better painting the Z900-a4 side-covers to match tank & tail, then fitting "DOHC900 " badges to them.
RegardZ
#6 PostAuthor: ADRIAN H » Wed Jul 08, 2015 12:56 pm
RegardZ
+1 the rear of the left hand panel clashes with the lock - you`d need to alter the side panel before painting.
I have been thinking about doing this to one of my bikes, you also need two Z1 rear engine mounting brackets (which have the side panels lower mounting point). Also cut off the mounting point to underside of battery to the left.
000zeds
#7 PostAuthor: 000zeds » Wed Jul 08, 2015 6:48 pm
RegardZ
My thoughts exactly :wink:
Zeds-R-Us
Chris Riv
#8 PostAuthor: Chris Riv » Wed Jul 08, 2015 7:09 pm
Why not just buy a Z1B :?:
