Spacer or not?
Kari
#1 PostAuthor: Kari » Fri Nov 17, 2006 5:32 am
If I use o-ring chain, must I use spacer to rear wheel sprocket or not? I have an early Z1A.
#2 PostAuthor: Rich » Fri Nov 17, 2006 6:19 am
Converting from std to oring chain won't affect the chain run but wou will have to take into account the orings will put approx 1mm extra width each side of the chain and check clearances accordingly.
Steve R
#3 PostAuthor: Steve R » Fri Nov 17, 2006 9:14 am
Kari ,
i have o ring chain on my z1a its no problem at all.
Regards Steve
