Z1, ZA or Z1B Rear sprocket carrier
DogsbolloxofZ1B
#1 PostAuthor: DogsbolloxofZ1B » Fri Aug 07, 2015 7:35 pm
Does anyone have a good rear sprocket carrier
going spare? In my house move I seem to have
lost it😁😁
Also, is the Z900 one the same? I seem to recall
it didnt need the spacer behind rear sprocket for
an O Ring chain.
Mike
wilsonsjw11
#2 PostAuthor: wilsonsjw11 » Fri Aug 07, 2015 7:37 pm
F**K me not again!!!!!
Thought I had one but just checked the garage an d it's gone , must have given it away.
Regards
Steve
Jeff Saunders
Re: Z1, ZA or Z1B Rear sprocket carrier
#3 PostAuthor: Jeff Saunders » Fri Aug 07, 2015 8:07 pm
DogsbolloxofZ1B wrote:Does anyone have a good rear sprocket carrier
lost it😁😁
an O Ring chain.
Mike
Part way through the z900-a4 production run, they changed the sprocket carrier to remove the need for a spacer.
The spacer was inserted on the Z1b and early z900 models because the new O-ring chain was wider.
DogsbolloxofZ1B
#4 PostAuthor: DogsbolloxofZ1B » Sat Aug 08, 2015 4:02 pm
Yes I can't believe it either😀
wilsonsjw11 wrote:F**K me not again!!!!!
Regards
Steve
walshyco
#5 PostAuthor: walshyco » Mon Aug 10, 2015 9:42 am
Hi Mike I have one if you still need one. It is a bit dirty but usable with a good clean up. If you want it just pm me your address and I will get it off to you. Sean.
DogsbolloxofZ1B
#6 PostAuthor: DogsbolloxofZ1B » Fri Aug 14, 2015 6:10 pm
Sean,
Great news! I've dropped you a pm.
Regards Mike
