Hi Guys,
Anyone know the width of a z1000 A1 or A2 swinging arm at the wheel spindle? mine came with cast wheels, scored a pair of spoked wheels but my swinging arm is a far too wide with the standard wheel spacers. My swinging arm is 245 mm so think it may have came from a J model like the wheels.
z1000A1 swinging arm
hi there I remember seeing that somewhere and sure enough on mine the bosses on the carrier are a different profile to the cush drive on the spoked wheel , when i stripped the bike and took off the cast wheel a load of washers fell out with the spacers and when I bought the spoked wheels they came with the sprocket carrier. I found an old post where someone was looking to fit wider wheel to a z1000 and he had 7 and 1/2 " from the swinging arm to the brake carrier mine is more like 8 and 1/2". I have fitted a zephyr 1100 front and back end and just getting all the standard gear together in storage to return to standard at a later date
Steve Cooke
- ZedHead
Steve Cooke wrote:The one hanging on my wall measures 227-228mm from an A2.
+1
