CSR 1000 front disc. any other model fit ?
stevie g
#1 PostAuthor: stevie g » Wed Sep 09, 2015 4:53 pm
Hi Guys, I'm not having a lot of luck finding a front disc for my CSR 1000. Every other model seems to be bigger or smaller. Does anyone know if any other bike shares these discs ? Or do you have one you might want to sell me, I've asked a couple of engineers up here if they could straighten my old one with no results, thanks $tevie.
stephen g mackay
hillbilly
#2 PostAuthor: hillbilly » Wed Sep 09, 2015 6:52 pm
dimensions and stud pattern might help.i have some z discs that might fit.
Gus
#3 PostAuthor: Gus » Wed Sep 09, 2015 6:59 pm
My investigation says they were only fitted to that model.
But as Hillbilly said if you get the dimensions somebody may have a set
Gus
"Set the GRINDER on it"
#4 PostAuthor: ADRIAN H » Wed Sep 09, 2015 7:53 pm
Sorry cant help - EDITED .
[b]WRONG WHEELS SHOULD BE SPOKED [/b]
hillbilly
#5 PostAuthor: hillbilly » Wed Sep 09, 2015 8:05 pm
I have a seven stud disc.similar.
#6 PostAuthor: z1bman » Wed Sep 09, 2015 8:53 pm
the spoked wheel model have a alluminium centre & only fit that model
#7 PostAuthor: Al » Wed Sep 09, 2015 9:16 pm
Are they not the same as the J?????
#8 PostAuthor: z1bman » Wed Sep 09, 2015 9:23 pm
no
johny brando
Re: CSR 1000 front disc. any other model fit ?
#9 PostAuthor: johny brando » Thu Sep 10, 2015 1:04 am
stevie g wrote:Hi Guys, I'm not having a lot of luck finding a front disc for my CSR 1000. Every other model seems to be bigger or smaller. Does anyone know if any other bike shares these discs ? Or do you have one you might want to sell me, I've asked a couple of engineers up here if they could straighten my old one with no results, thanks $tevie.
I've just looked a set of GPZ 1100 B2 front disc's & they look absolutely exactly the same as yours ! they measure up @ approx 285mm O/D & 130mm I/D , same & 7 bolt fix , same disc drilling pattern, same disc face rebate..........I recon it could well be them !!!
Hope this helps . Johny Brando.
stevie g
#10 PostAuthor: stevie g » Thu Sep 10, 2015 7:37 am
They are 270 OD x 5mm thick x 4 bolt fixing. Mine is the CSR M1 wire wheel. There are lots that look the same but are usually too big a OD
stephen g mackay
sid123
#11 PostAuthor: sid123 » Thu Sep 10, 2015 10:43 pm
get them turned down on lathe of od too big
whoosh im gone
stevie g
#12 PostAuthor: stevie g » Fri Sep 11, 2015 6:16 am
Cannot do that cos the drilled holes will be either too close to the edge or actually on the edge and don't think there's any out there that are not drilled as standard.
stephen g mackay
johny brando
#13 PostAuthor: johny brando » Fri Sep 11, 2015 6:52 am
I was using the photo that was shown on this thread ( & is now "not displayed any more !!!!" as the reference for my above reply ) why did I bother to measure check & reply !
stevie g
#14 PostAuthor: stevie g » Fri Sep 11, 2015 1:29 pm
As Z1bman says, Alloy centre fixing is 8 rivets, 4 bolt pattern fitting to wheel, 270 mm OD 130 ID x 5 mm . Even if I could get one with same OD and ID but with a different Alloy centre maybe I could get it changed, or is that possible ?
stephen g mackay
RGH
#15 PostAuthor: RGH » Fri Sep 11, 2015 2:36 pm
Users browsing this forum: No registered users and 97 guests
