ST rear caliper retaining bolt
Hi, I have searched high and low to try and work out if the rear caliper retaining bolt on the ST that fits through the swingarm should unscrew completely. The outside bolt on mine comes off to reveal a bolt with no thread on it. Instead it seems to be a permanent fixture to the caliper which made removing the wheel a right pain in the arse because the wheel had to come out first (bevel and all) just to move the caliper! Any help appreciated. Manual says remove the bolt so I presume someone has been at it.
1979 Z1000ST
the one in the photo is for the z1300.
this is the correct part no for your z1000st
http://www.ebay.co.uk/itm/Kawasaki-NOS- ... 1200326436
i presume it was you who purchased this one ??
http://www.ebay.co.uk/itm/Kawasaki-Z100 ... 7675.l2557
