cam chain tensioner
cam chain tensioner
could someone tell me the procedure for adjusting the cam chain tensioner on a 1977 Z1000. The one on the back of the block adjacent to the oil pressure switch. I have had mine apart and the plunger is not reacting to the spring pressure, it apears to be fixed in one position. I only took it off to remove the starter motor. The Haynes manual doesn,t give me a clue at all.
cam chain tensioner
Thanks for that chaps, thats answered my question.
twozeds wrote:The tensioner should only be used or removed when engine is set at TDC 1+4 cylinders
+ 1
