Spacers
Dodgy Z1B
Spacers
#1 PostAuthor: Dodgy Z1B » Tue Sep 29, 2015 6:03 am
Will be fitting standard swinging arm soon but was wanting to check the correct set up for the front sprocket and wheel spacers. At the moment I have no spacer fitted to the inside of front sprocket is this correct for z1b and what would be the standard size for the rear wheel spacers ?
Dodgy Z1B
#2 PostAuthor: Dodgy Z1B » Fri Oct 02, 2015 5:47 am
I find it very difficult to believe that no one on here dosent know the correct set up (spacers) for front sprocket and rear wheel maybe just can't be arsed replying 😀 The problem I have is a non standard swinging arm which I am changing for a standard item but to get the non standard item to work all spacers have been messed about with so any help with this will be greatly appreciated
#3 PostAuthor: ADRIAN H » Fri Oct 02, 2015 8:42 am
What are you looking for - length of spacers x external diameter.
Standard swing arm just has dust covers / caps to each end.
If you go to the downloads page on the link, there is a downloads page which has Z1B parts list, which will give you part numbers for rear wheel spacers - http://classickawasaki.se/
Brake side spacer / collar - Kawasaki part no 42032-037.
http://www.ebay.com/itm/1973-77-kawasak ... 95&vxp=mtr
Sprocket side spacer / collar - Kawasaki part no 42037-023
http://www.ebay.co.uk/itm/75-Kawasaki-Z ... 4ad11bf30f
I can measure a rear brake spacer if you wish, I may have a spare ?
Not sure if I can measure the sprocket as the spacer sits partially within oil seal.
wheelysteve
#4 PostAuthor: wheelysteve » Fri Oct 02, 2015 8:46 am
I've got completely standard Z1b's and the drive sprocket is fitted without a spacer but one side has a raised boss which goes on the transmission side, thus spacing it out slightly.
The rear sprocket has a spacer behind it, approx 1.5mm thick.
This is using standard 630 o ring chains.
This shows the side to fit to the gearbox]
This is the spacer behind the rear sprocket
Hope this helps, Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Dodgy Z1B
#5 PostAuthor: Dodgy Z1B » Fri Oct 02, 2015 5:59 pm
Thanks my front sprocket doesn't have a raised boss the chain just misses the casing I'm using a 630 chain does I have seen 1.5mm spacers on z1 enterprises site my rear sprocket has the spacer as described once I have removed the swinging arm and fitted original item I think I might just need to sort front sprocket out thanks for replies.
