Piston Ring end gap size, 810 kit.
GPRD
#1 PostAuthor: GPRD » Fri Oct 02, 2015 1:13 pm
I bought some of those pistons from cruzin image in Japan a while ago and I've had barrels rebored by SEP to their size.
The help I need is, I want to make sure the end gap size is within tolerance, but I can't find what the minimum should be, the workshop manual says the max is 0.7mm, but there's no minimum, can anyone advise how I work it out?
What we got here, is failure to comunicate.
GPRD
#2 PostAuthor: GPRD » Fri Oct 02, 2015 2:28 pm
Also, how do I know which is the top ring and the second ring?
They're usually marked, but these don't seem to be.
cheers
KWACKERZ1
#3 PostAuthor: KWACKERZ1 » Fri Oct 02, 2015 2:50 pm
the book says, ring gap.
1000cc
0.016in to 0.032
0.4mm to 0.8mm
900
0.012in to 0.028
0.3mm to 0.7mm
The standard 2nd ring has a notch on the end.
GPRD
#4 PostAuthor: GPRD » Tue Oct 06, 2015 12:00 pm
Cheers, I'll go with 0.3 to 0.7.
#5 PostAuthor: z1bman » Tue Oct 06, 2015 6:00 pm
top ring is the one with the silver outside edge
