Removal or POR15 tank sealant
ROZZER
#1 PostAuthor: ROZZER » Sat Oct 10, 2015 8:52 pm
Just got a 350lc to go wiv my zed. Tank has been sealed with POR15 and for some reason it is peeling off in big lumps (must be poor application cos the stuff is supposed to be good) anyone know how to remove it so I can reseal? Paint is mint so dont want to damage it in the process of removing the sealant.
cheers
John
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
BykerBoy
#2 PostAuthor: BykerBoy » Sun Oct 11, 2015 3:53 pm
Get some acetone from ebay it removes it pretyy easily
ROZZER
#3 PostAuthor: ROZZER » Sun Oct 11, 2015 8:17 pm
Cheers Bykerboy Ill give it a go mate.
John.
#4 PostAuthor: Al » Sun Oct 11, 2015 8:25 pm
Might be worth having a word with Frost Auto Restoration. (they sell POR15)
Part of the installation kit is 'marine clean'.
Could this be acetone / nail varnish remover, by another name??
http://www.frost.co.uk/
ROZZER
#5 PostAuthor: ROZZER » Mon Oct 12, 2015 5:10 pm
Al,
Tried Frost at first point of call but no joy, told 'they just sell the stuff' so no help.
I think maring clean is a detergent though.
John
Redbeard
#6 PostAuthor: Redbeard » Mon Oct 12, 2015 6:26 pm
Must have been poor prep, this is the first case I have heard of POR15 lifting. I have used it twice with no issues so don't let this put you off. Marine Clean won't budge it, it'll likely require some evil chemical of some sort. If you re-do it with POR15 be sure not to get it on the paint. My tank has had something like petseal in there from a previous owner which is a bloody nightmare! Peels off easy. Best of luck..
1979 Z1000ST
Garn 1
#7 PostAuthor: Garn 1 » Wed Oct 14, 2015 11:11 am
Rozzer, are you sure it was POR15 initially.
It sounds like that other product.
I've never seen POR15 peel.
Perhaps the problem may be solved with another kit of POR15 and re-do! Ensure you get rid of any loose stuff!
RegardZ.
ROZZER
#8 PostAuthor: ROZZER » Wed Oct 14, 2015 4:05 pm
GARN1 deffo POR15 as cofirmed by previous owner who was also surprised as he has used it many times. POR have advised using their strip gel then marine clean amd then metal prep so I will be re applying POR15 as its generally accepted as being the best stuff. Poor prep I reckon by previous owner. Will have to be ultra careful not to trash the paint.
#9 PostAuthor: ADRIAN H » Wed Oct 14, 2015 4:10 pm
ROZZER wrote:GARN1 deffo POR15 as cofirmed by previous owner who was also surprised as he has used it many times. POR have advised using their strip gel then marine clean amd then metal prep so I will be re applying POR15 as its generally accepted as being the best stuff. Poor prep I reckon by previous owner. Will have to be ultra careful not to trash the paint.
Good luck.
BykerBoy
#10 PostAuthor: BykerBoy » Wed Oct 14, 2015 6:48 pm
To look after the paint I wrap the tank in cling film then cover it in tin foil then cling film again, repeat a few times then cut a hole where the petrol cap goes and trim it neatly.
Users browsing this forum: celger7 and 36 guests
