main Jets
PETER KZ1A
main Jets
#1 PostAuthor: PETER KZ1A » Mon Nov 02, 2015 9:00 am
standard bore z1a , was running 117.5 main jets , bogsdown ,sooty plugs , needles at #3 , put standard 113's in , kerker 4-1 ,standard airbox ,
113's too lean?
Had the carbs chemically cleaned
PAULJAC47
#2 PostAuthor: PAULJAC47 » Mon Nov 02, 2015 9:15 am
Probably had the larger jets to suit the Kerker, 113 may be too small,with larger jets fiited check out mixture with a Gunsons colurtune/May be worth checking seating of choke plungers,good 12 volts at coils,dropping needle one clip at a time,see if improves sootyness with filter out.try good run and get engine up to temp for a plug chop,dont just run bike on stand plugs wont get to self cleaning temp,if using Ngk plugs replace with nippon denso w24-es..Cheers Paul J
jimmock
#3 PostAuthor: jimmock » Mon Nov 02, 2015 9:21 am
Now that is a "proper" answer!!!
Jimmock. :wnkr
I hate people I don't like !
