gpz 750 UT engine badges
stevie g
#1 PostAuthor: stevie g » Thu Nov 12, 2015 7:55 pm
Hi guys. Does anyone know where I might get the above ? I know I can buy decals but would much prefer aluminium discs with the GPZ logo. Thanks to all replies, $tevie.
stephen g mackay
stevie g
#3 PostAuthor: stevie g » Thu Nov 12, 2015 8:38 pm
Thanks Crofty. They are dear eh, as usual. Wonder if anyone is making aftermarket ones ?
stephen g mackay
Crofty
#4 PostAuthor: Crofty » Thu Nov 12, 2015 9:52 pm
Only the decal type AFAIK
stevie g
#5 PostAuthor: stevie g » Fri Nov 13, 2015 8:39 am
yea i've seen them. ok bud thanks again.
stephen g mackay
garyd
#6 PostAuthor: garyd » Fri Nov 13, 2015 8:45 am
Try looking here...seems to have a good stock.
http://www.reproductiondecals.com/defau ... .html~main
#7 PostAuthor: Ginger Bear » Fri Nov 13, 2015 9:04 am
If the cases are anything like the 1100 Unitrak the surfaces will be convex, not flat so applying decals ain't gonna be easy.
I bought the genuine articles from Z-Power & while they ain't cheap, they are absolutely spot on. :D
j.b
#8 PostAuthor: j.b » Fri Nov 13, 2015 7:46 pm
if you join 750turbo.com there was a member on there who had a batch excellent repro alloy badges made....well worth checking out
stevie g
#9 PostAuthor: stevie g » Sat Nov 14, 2015 1:20 pm
Thanks guys. Ginger bear, the casings are flat so if need be the decals would go on no probs, but I would like ali discs if poss. $
stephen g mackay
