Z1000J Build
LeeJackson
Z1000J Build
Hi all,
So this is my first Zed project for a while, long overdue to be honest!
We just moved to France so after the initial bs that you have to get set up when you move I managed to start trying to find a new project..I was looking for an early Zed but couldn't find anything so decided to go for this Z1000J
It looks fairly good in the Photos (Sorry not the best of photos) but needs some work.. The Last 3 bikes I have built have been Restos, so Im afriad as original as this one is it has to be a special....
Bike was running and road legal, lots of oil leaks, no brakes, the usual sort of thing..
LeeJackson
phots added..
Damn that took a while..
OK Here goes, bike as collected;
Sorry about the Hazy Photos and crap French cars in the background
LeeJackson
Tear Down
So I decided to do this bike the opposite way from my normal and do the engine first..
When stripping the engine I discovered it had just been re-bored and has a new Wiseco Kit in it.. Boost if they had not broken half the fins off the barrels when rebuilding, so guess they are junk.. Ive not measured the pistons but dont think they are much oversize..
I have not decided exactlly what to do with it yet.. But for sure the Crank will need to be done, so it got shipped off to Debbens in UK a few weeks ago for re-build and welding. I'm thinking to go for GPZ Barrels and put a 1200 kit in it, what do you guys think? I won't do huge miles on the bike, but want something that will run decently and not cause me heaps of grief trying to dial it in all the time.. Of course some head work will need to be done.
LeeJackson
So plan was to re-build engine and leave the chassis alone.. But i got bored and my 6 year old son was deseperate to take more things to bits with me
Good training I'd say.. So bike got stripped
I found a really good shop doing blasting and powder at the otehr side of paris called Abdeco, so took my frame and crankcases to them..
Frame came back on Saturday, great job done..
Plan was to have the crankcases done in the High Temp Ceramic coating, I was pretty impressed with the samples they had in teh shop.. However my slighty bad eyesight missed a horrible bodge on the crankcases which was unvailed during blasting...
Not so good... Now the thing is, can I get these fixed by anyone? Or Should I just get another set and start again? What do you think?
LeeJackson
No definatly something interesting.. The bike is really quiet complete and correct so its almost a shame, but my last 3 rebuilds were all full stock restorations, so this time it has to be different...
Im trying to figure our running gear just now, looks like ZRX gear is a fairly straight forward fit, so trying to keep my eye out for a front and rear end to get it rolling for a start.. I have some bigger plans longer term, but lets ssee how the budget goes.. Like I say this time Im doing the engine first and play with the shassis when I have some spare cash and time
So anyone know who can do this repair? I'm still trying to figure out who can do what in this country, so everything is taking too long
Sadly I can't help, but being where you are there has to be someone capable, particularly knowing the French history of Zeds....
If you're thinking of staying period with your chassis updates have a look at my thread. My old J goes around corners much better than it should!
http://z1ownersclub.co.uk/forum/viewtopic.php?t=35470&postdays=0&postorder=asc&start=0
LeeJackson
So finally I have an update on the J.. I git the ZRX1200 Swingarm powder coated, but they had to rework it about 6 times and it took over two months to get it back. Unfortunately it still doesn't look quiet perfect, a few imperfections, but it will have to do..
Anyhow I promised to post some photos of my approach to fitting it to the J.. Simple as possible being the name of the game as I have no facilities to do any machining here and my French is crap so I wouldn't know where to start finding one..
Anyway first I fitted new needle bearings both sides.
I wanted to also fit the correct 16mm ID of Roller bearing rather than try to sleeve it. unfortunately the closest bearing you can get is a 6302/16 which is 13mm wide, vs the original 12mm one.
There was plenty of meat on either side of the rollers so I lapped off 0.5mm from each side using a grinding stone and take it to 12mm width
So next issue is the 16mm spindle with the 20mm Sleeve. For that I bought some Oilite bushes..
Then they were slid inside the new inner race until it was full..
You can see it leaves a very small gap in the length, but really no big deal when the whole thing is a very snug fit so I went with that
Next I had to remove a couple of mm from the standard spacer that comes with the ZRX arm and sleeved that with a short bushing just for the sake of it. Really I don't matter as it just sits in a seal and stops sideways movement.
I refitted the standard Oil seal on the right hand side of the arm.
The Left side of the arm does not have an oil seal in it, on the ZRX the principle is slightly different, but leaves it a little exposed unfortunately on the Zed to dirt. I managed to get an O-Ring the right size to fit in just to guard slightly from dirt and dust...
LeeJackson
- Ginger Bear
LeeJackson
some progress today.. Got a rolling Chassis again..
Sorry about the crap photo, looks like lens was a bit dirty..
Guys, so now I need to buy some shocks, the ride height is concerning me, and I never measured anything up before dismantling, which was in hindsight a bit stupid
Anyway I have 260mm to the bottom of the frame with no weight.. Any ideas where we would be normally for a thou unladen?
