Cam Timing Help - Please
Wingman
Hi,
I'm hoping that someone will be able to help me with what is probably a stupid question. I'm just in the final stages of getting my bike back together after years off the road and am puting the camshafts in the trouble is I can't decide what postion the exhaust cam should be in when setting up the cam timing. There are 2 marks on the cam sprocket rubber which I thoght should be parallel to the head but then I also thought that the slots on the ends of the exhaust and inlet cams should point out - but both these can't be true - wish I'd looked before I'd taken it apart. Any help really appreciated.
Thanks.
Thanks.
Wingman, the marks on the cam sprockets, aligned with the sprocket bolt, should point outwards, in line with the top of the cylinder head
The sprocket mark is the one thats level with the single bolt, opposite the 'pair' of bolts on the sprocket
Fit the cam chain & take the first link pin, after the mark on the ex cam, level with the head. Count to 28th pin, which should line up with 28 mark on inlet cam sprox.
Timing marks - 1:4 aligned (1 & 4 TDC)
This is for early round cam cover zeds Z900 & early 1000's
Wingman
hi,i was checking my cam/timing yesterday ,and it looks like my inlet sprocket is 1 tooth of place ,in a clockwise direction,at least thats what i think,should the cam arrow line up directly with the cylinder surface ? i,ll try and post a pic of it tonight ,another question , would that explain 1 & 2 cylinders running rich and 3 & 4 lean ?
thanks guys
thanks guys
what,s there to say except we,re all mad on here.
Pigford wrote:Wingman, the marks on the cam sprockets, aligned with the sprocket bolt, should point outwards, in line with the top of the cylinder head![]()
The sprocket mark is the one thats level with the single bolt, opposite the 'pair' of bolts on the sprocket![]()
also the same for the proper square cam cover Z1000s as well..........
Steve Cooke
- ZedHead
bigmac take a look
bigmac103 this is the only way I know how to bring it up i'm not as computer friendly a some on here, good pics from chrisu which should help you.
Steve Cooke
- ZedHead
Users browsing this forum: Big Fluff and 89 guests
