Z1r Firing problem
Z1r Firing problem
Been working on a mates Z1r,bike would stop firing on no2 pot, so fitted new coils ,new Dyna s,new leads,Nippon Denso plugs,new plug caps,Still stopped firing on N02 pot,swapped leads 2 and 3 now stopped firing on no3 and n02 fires ok good 12volts at coils(wired George mod)..Any thoughts?
- Ginger Bear
My thoughts exactly guys, but all new components and the fault is exactly the same,new leads, plugs .dyna,caps,might try swapping coil and leads for 1 and 4 with coil for 2 and 3?
forgive me big lad...but did you swap the leads in the out puts as well or just the lead cos if its following the lead take one of the myriad of other bikes you have and try that
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Keith brand new coils with sealed in leads,new caps,plugs,swapped 2 and 3 over at plug cap end and fault transferred from 2 to 3.But works when you first fire her up just fails after a while?
Jim tank is off,no arcing.
Was same fault b4 we replaced all the ignition components!
One thing i have noticed is that the lead that goes to the pot that fails ,either 2 or 3 shows intermittent firing when you put the clamp from the strobe light across the ht lead
"One thing i have noticed is that the lead that goes to the pot that fails ,either 2 or 3 shows intermittent firing when you put the clamp from the strobe light across the ht lead"
Paul, sounds like that new lead is breaking down ??
Jimmock.
I hate people I don't like !
