42-44mm Ramair Filters and period J-type clocks or a Koso T&
Coose
#1 PostAuthor: Coose » Sat Jan 09, 2016 5:30 pm
Evening all,
As above I'm after a set of Ramair filters to fit the VM29 carbs on my J. I currently have a mismatched set of K&N type filters, but I'm more of a fan of foam filters. 42-44mm should fit.
I'm also after a set of clocks for it. Brian the Z1100R chap has sent me down the path of the lovely little Koso combined tacho and speedo/idiot lamps unit, but before I bite the bullet and shell out £160+ on one I thought it would be worth asking if anyone had one kicking around?
The other option would be a J/CSR electronic tacho and some sort of mechanical speedo, though I'm still undecided as what to do. Currently my Zed has GPz550 clocks which aren't the nicest, and I would like to change them for either a single offset unit or separate clocks.
Does anyone have anything interesting?
