Z650 wire wheel is it the same as Z1000
Padders
#1 PostAuthor: Padders » Sun Feb 03, 2008 9:12 pm
Hi looking for some hubs to build some wider wheels for the Z1000A2. I am going to an 18 inch front from 19 and an 18 inch rear but wider to take a 150. Is the Z650 front hub the same as the Z1000 Z900 hub. Also is the KH250 one the same.
Any advise gratefully accepted.
steve f
#2 PostAuthor: steve f » Sun Feb 03, 2008 10:08 pm
kh500 and z650 are the same wheel
000zeds
#3 PostAuthor: 000zeds » Mon Feb 04, 2008 7:53 pm
Not 100% sure but i think KH250/400/500+ Z650/750/900/1000 all use same hub 4 bolt brake disc mounting. Diameter of KH discs is smaller.
Zeds-R-Us
#4 PostAuthor: Pigford » Mon Feb 04, 2008 8:03 pm
Padders, had a look at my bikes & the Z650 looks a bit smaller, but I can only compare the 650 wire/drum to me Z1000 wire/disc rear wheel :?? :(
If you need any dimensions I will try to dig the 650 out of the back of the garage & measure it for you :wink:
Users browsing this forum: Tony and 33 guests
