Oil Cooler for a Shed
Fred the Zed
#1 PostAuthor: Fred the Zed » Tue Feb 09, 2016 5:51 pm
I need some help please guys...
I'm thinking of fitting an oil cooler to my Shed1R.
Option 1. Buy an Earls kit from Wemoto.
+ Its a complete kit so I know it'll fit and it'll have all the right bits.
- Its £330 plus postage. :shock:
Option 2. Make up my own kit, sourcing bits from different places.
+ It'll be about 50% cheaper.
- I'm no expert on fluid dynamics.
Coolers are available for different applications or universal fits eg
http://www.ebay.co.uk/itm/231554701417? ... EBIDX%3AIT
Oil Cooler fittings are available eg
http://www.ebay.co.uk/itm/272038877747? ... EBIDX%3AIT
And I could get the hoses made up by Torques (as recommended by GB)..
Question is 'It appears that the fitting are drilled and tapped for 1/4" fittings but the cooler has a 22mm outlet. Are these compatible or will the cooler be starved of oil and not do its job? (or am I over thinking it?).
I'd appreciate your advice
Fred
Paid Up Member
#2 PostAuthor: Pigford » Tue Feb 09, 2016 6:05 pm
If it's 1/4" BSP - thats much bigger than a real 1/4" :lol:
Fred the Zed
#3 PostAuthor: Fred the Zed » Tue Feb 09, 2016 6:45 pm
Pigford wrote:If it's 1/4" BSP - thats much bigger than a real 1/4" :lol:
Its 1/4" NPT whatever that means.....
Fred
Paid Up Member
#4 PostAuthor: Ginger Bear » Tue Feb 09, 2016 6:48 pm
Fred,
Torques won't make the lines for you, they just supply the parts.
I have posted a youtube vid on one of these oil cooler related threads that shows how to 'fit' the fittings. It really is a piece of piss when you know how, anyone can do it.
These are by far the best value brackets on ebay, if you don't want to make your own...... http://www.ebay.co.uk/itm/Silver-Setrab ... DoHHQiO3Yg
I've had a couple of coolers from this lot, they are a generic size & will fit the brackets I've just posted. 10 row will be more than enough. Either buy the cooler on it's own & add all the hoses and fittings from torques, or if you want to save a couple of quid, buy a kit with the longer hoses & chop the fittings from the take off end & use a barb fitting with hose finishers, as I did on my 1170R project. (You'll need to dig to around 2011 to find that)
http://stores.ebay.co.uk/MG-PARTS-AND-A ... oil+cooler
#5 PostAuthor: chrisu » Tue Feb 09, 2016 7:38 pm
I did the whole lot for about £100
All new parts
