GPz1100 oil cooler onto a "J" ?
#1 PostAuthor: Pigford » Sun Feb 14, 2016 2:52 pm
Maybe a daft question - by I assume a GPz1100 B1/2 oil cooler system will fit straight onto a Z1000J :?:
martinz1000r
#2 PostAuthor: martinz1000r » Sun Feb 14, 2016 3:39 pm
i think so. I think the J just has the pressure switch behind the barrels and the take offs then just bolt on with the switch integral.
If you need the parts I can probably sort out oil cooler, lines and take off plus even the mounting point for the frame although I think the twin horn mounts have been removed. I think i have both ELR and GPz Unitrak in the shed.
As it's you a special (inflated) price could be agreed :twisted:
#3 PostAuthor: Pigford » Sun Feb 14, 2016 3:58 pm
martinz1000r wrote:i think so. I think the J just has the pressure switch behind the barrels and the take offs then just bolt on with the switch integral.
Martin, appreciate that - cheers matey.... only need the mounting plate if I go down that route :wink:
