cyl head
ogre
cyl head
#1 PostAuthor: ogre » Fri Feb 19, 2016 4:38 pm
hi all after gettin my z1 head replaced by the powder coaters who melted my original long story .just realised the one he replaced it with has been ported by the looks of it on the inlets to 33-34mm not well up on doin mods will it effect anything if i put the standard manifolds on and the original 28mm carbs.
thanks ogre
PaulMceleney
Chunks
#2 PostAuthor: PaulMceleney » Fri Feb 19, 2016 5:36 pm
no should run better
PaulMceleney
Chunks
#3 PostAuthor: PaulMceleney » Fri Feb 19, 2016 5:40 pm
IF IT GOT BIGGER VALVES I WILL SWAP YOU FOR A STANDARD HEAD OF A Z1R
ogre
#4 PostAuthor: ogre » Fri Feb 19, 2016 6:12 pm
no dont think it has bigger valves but valve spring holes have bin cut back a bit must have had funky cams
