Set up
King of Kings
Set up
#1 PostAuthor: King of Kings » Fri Feb 26, 2016 10:56 am
Hey all, what's the throttle slide gap for VM26 carbs when setting up static on the bench? :)
#2 PostAuthor: Pigford » Sun Feb 28, 2016 1:26 pm
Doesn't matter - so long as you get a base setting that they all match!
Most peeps use a ball bearing or drill bit to set them. Ball bearings is best as you can use 4 x and see when they fall out :wink:
