hello gents the fast idle on my gpz1100 isn't working properly. the choke part works fine but as soon as you put the lever down to fast idle it just goes onto normal tick over. everything seems to checkout ok on the bar mechanically is there something else i could check.
many thanks in advance john
fast idle problem
