brake caliper
PaulMceleney
- Chunks
brake caliper
I striped my rear brake caliper this is a six pot pretech caliper I want to remove the pistons have manged to remove three on one side but the other side seem to be stuck whats the best way to free these pistons thanks
PaulMceleney
- Chunks
brake caliper
Grease gun as Paul said. Put the caliper back together if split, put pistons back in and clamp the free ones. Block the fluid inlet with washers and the banjo bolt, then apply a grease gun to the bleed nipple ( opened of course ). Grease gun can apply massive pressure, and when a piston comes out, you just have a blob of grease, not fluid all over the place.
Grease gun has never let me down, even on badly rusted pistons.
Be sure to very thoroughly clean out the caliper holes, tubes and threads before re-assembly.
He who dies with the most toys wins .
PaulMceleney
- Chunks
