tyres
ogre
tyres
#1 PostAuthor: ogre » Mon Apr 18, 2016 8:04 pm
hi all lookin at buyin bt45's for my z1a do i go for 100/90-19 and 120/90-18 v rated tubeless if so can you still fit a tube in on a standard steel rim cos i dont think they do a tube type.
thanks
#2 PostAuthor: chrisu » Tue Apr 19, 2016 8:02 am
i have - no problem
ogre
#3 PostAuthor: ogre » Tue Apr 19, 2016 8:52 am
cheers thats what i will do then
tlc
#4 PostAuthor: tlc » Tue Apr 19, 2016 2:34 pm
I would go for stock imperial sizes.
They're still tubeless but in particular the rear will wear better.
GinjaDave
#5 PostAuthor: GinjaDave » Fri Apr 22, 2016 12:26 pm
If you want an innertube there's one here.
http://www.ebay.co.uk/itm/131323564767? ... EBIDX%3AIT
So this is probably a stupid question but here goes anyway, if you don't put an innertube on a spoke wheel, wont the air escape out through the spokes? :roll:
Of all the things I've lost I miss my mind the most
floydsz1
#6 PostAuthor: floydsz1 » Fri Apr 22, 2016 12:57 pm
So this is probably a stupid question but here goes anyway, if you don't put an innertube on a spoke wheel, wont the air escape out through the spokes? :roll:[/quote]
Not if its a bmw. Think guzzi are the same. The spokes are fitted in the side rather than the middle in a seperate bit on the rim etc so not actually inside the tyre.
johny brando
BT -45's Tires
#7 PostAuthor: johny brando » Sat Apr 23, 2016 4:17 am
ogre wrote:cheers thats what i will do then
Thats a very good choice of Tire. I run BT 45's on mine and there brilliant ,very planted ! & definitely stick to STD sizes Tires on Std rims or you will regret it ...handling will be lesser ! Try not to get caught up in this whole big tire thing , as there's a lot more to it than meets the eye . It will rob your H.P. if you have 125 hp plus, well yes .....you need a bigger footprint on the tarmac then & you can afford to sacrifice some Ponies for the privilege. This is why you won't see 120 front & 200 section rear tire's on a Manx Norton or G-50.
ogre
#8 PostAuthor: ogre » Sat Apr 23, 2016 4:34 pm
thanks for that so the std sizes state they are h rated not v is this ok.
#9 PostAuthor: chrisu » Sat Apr 23, 2016 4:37 pm
up to you - i run (and always have) metric tyres that are V rated and don't have a problem. Having said that i don't do 130+ on my Z.
Bill Newman
#10 PostAuthor: Bill Newman » Sat Apr 23, 2016 7:44 pm
chrisu wrote:up to you - i run (and always have) metric tyres that are V rated and don't have a problem. Having said that i don't do 130+ on my Z.
Yes you do -even though you always claim your sat nav says 70😜
