GPZ11 Unitrack problem
- paul doran
One of Our lot over here is having a problem with His 1100 Unitrack it still has it injection system fitted when He runs the bike it is showing a fault 1 long flash on the led display followed by 3 short flashes He only has the handbook and its says it's the heat temp sensor any ideas
- Ginger Bear
The connector to the sensor is prone to corrosion, as is the wire.
Cut the connector off & strip back the wire to expose some nice fresh copper.
Then fit a new connector.
From memory, the sensor also fits into a boss, then screwed into the head. It's worth taking it all out & checking both sets of threads for corrosion, as these will effectively increase the resistance of the sensor.
