Seat strap - Z900 a4
Sorf
#1 PostAuthor: Sorf » Thu Dec 07, 2006 8:01 am
G'day all,
Question regarding the seat strap on the A4.
Not being able to find a decent seat here in Oz, I'm modifying a KZ seat with a Doremi strap. The question is, should there be some form of anti-scuff pad or buffer between the chromed clip and the seat vinyl?
Seems as though the metal would give the seat a hiding over time.
Any ideas?
Glenn
Begging your pardon sir, but you did say that you'd like .................a green one?
Ed Z1-R
#2 PostAuthor: Ed Z1-R » Thu Dec 07, 2006 8:27 am
Glenn on the z1r which i would think same as other zed models,there is no buffer for buckle to seat. Only a bit of tin plate on the strap as its threaded through the buckle.The only damage that ive noticed is the "headless" screw on the strap will/may pierce the seat vynyl but thats not visible as noted when i stripped the seat down after 20 odd years. Hope this is of help mate :)
