So, I got a new chain and both sprockets, some new brake shoes and cush drive. Dropped the back wheel out this morning and thinking a whole heap of good was going to be done, but - I think I might have missed a bit.
The DID 630VS O Ring Chain I got - no piggin' master link ! - Should there be one in the chain box or do I have to buy one ?
And if I do have to buy one - are the ones advertised for DID 630V ok for a chain marked 630VS ?
And assuming I do have buy one -should I use the hollow rivet or solid rivet version ? I do have a chain breaker/maker and assume the hollow version is easier to flare?
I know I must stay well away from a clip version.
Cheers Muckers
900-A4 Chain Question
UK '76 Z900-A4. On the edge or in the hedge (usually the latter)
Thanks for the help
Guess what was hiding in the sprocket packing - a chain link kit - whoo hoo.
Crackin' on !
One other question - about the front sprocket - I thought a 900-A4 front sprocket has a raised bevel on one side (the inward face). My original does - the new one doesn't - does that matter ? - I'm thinking of putting a washer behind to create the bevel as the chain is running mighty close to the casing.
Without the bevel - wont the back and front sprockets be a millimeter or so out of true ?
Crackin' on !
