Carbs
mikey
Carbs
#1 PostAuthor: mikey » Wed May 11, 2016 4:02 pm
Having trouble balancing the carbs on my gpz900r
So took them off to perhaps clean them check float heights etc but I noticed the butterfly flap on number 2 carb is slightly open more than the other 3 and no matter how much you turn the balance screw it wont level up could it be bent or twisted somehow ?
#2 PostAuthor: z1bman » Wed May 11, 2016 7:50 pm
slacken the two screws that secure it to the spindle & snap open the throttle a few times it should self align. if it doesn't it could be bent ?
mikey
#3 PostAuthor: mikey » Wed May 11, 2016 8:14 pm
Cheers mate ill try that
GPRD
#4 PostAuthor: GPRD » Thu May 12, 2016 7:36 am
It could be in the wrong way round, I found that with some Keihins I was rebuilding.
What we got here, is failure to comunicate.
