Switch gear paint
GinjaDave
Switch gear paint
#1 PostAuthor: GinjaDave » Tue May 17, 2016 2:49 pm
I'm in the process of restoring my Z1000 A1 and the switches look a bit tatty, I would like to restore the original switch gear, so does anyone know what is the best paint to use on them and are there any ideas on how to redo the lettering. I have looked on you-tube but can't find anything. :roll:
Of all the things I've lost I miss my mind the most
#2 PostAuthor: ADRIAN H » Tue May 17, 2016 2:58 pm
I think there is a member called zedman who refurbs switches he may be able to help. send a pm through link below.
Last set I painted I used a brush applied Humbrol Satin black paint.
http://www.z1ownersclub.co.uk/forum/vie ... ght=switch
mick znone
#3 PostAuthor: mick znone » Tue May 17, 2016 3:35 pm
i like to use matt black with a clear lacquer on top, i find that gives a deep satin look.
needaz1100r
#4 PostAuthor: needaz1100r » Wed May 18, 2016 8:28 am
mick znone wrote:i like to use matt black with a clear lacquer on top, i find that gives a deep satin look.
I like that idea, I've never been satisfied with 'satin' as it comes.
Cheers,
Mark.
#5 PostAuthor: warren3200gt » Wed May 18, 2016 8:31 am
Simonez Tough Paint Satin Black.
GinjaDave
#6 PostAuthor: GinjaDave » Wed May 18, 2016 12:54 pm
Thanks warren Simonez it is then, I may well try the clear lacquer as too.
pertonpc
#7 PostAuthor: pertonpc » Wed May 18, 2016 3:11 pm
You can use a cocktail stick to add in the white & red bits. :lol:
#8 PostAuthor: warren3200gt » Wed May 18, 2016 6:25 pm
If you want the the red and yellow lettering to really look good do them white first. When dry then do red or yellow over the top.
both red and yellow don't have enough colour pigment to cover the black underneath properly.
RALPHARAMA
#9 PostAuthor: RALPHARAMA » Thu May 19, 2016 5:48 pm
For a really nice job get Griffs Reality Motorcycles to powder coat them. He will put it on so you can barely tell it's not paint.
If I'm feeling skint I use a two pack satin black, but you do need to use a etching wash primer first.
I use Humbrol model enamel paint and a very fine Harris artists brush and glasses these days :( A white base will give them more zinc. The last I did were for a customer's Jota.
Ralph Ferrand
Users browsing this forum: No registered users and 81 guests
