Ignition key
Dunlop4
Ignition key
#1 PostAuthor: Dunlop4 » Fri May 20, 2016 10:59 am
I have an ignition switch without a key, for a z1b i think. there are two sets of markings on it Z 70 and 7 68. On ebay some is selling original keys is 768 the code?
BykerBoy
#2 PostAuthor: BykerBoy » Fri May 20, 2016 12:08 pm
Z1B keys are numbers 751 to 755 :D
Dunlop4
key
#3 PostAuthor: Dunlop4 » Fri May 20, 2016 5:55 pm
what i mean is the number on the ignition barrel, the number for ordering original keys. Has anyone carried this out and got the right key?
#4 PostAuthor: warren3200gt » Fri May 20, 2016 6:49 pm
Let you know when a seat lock key for a 650 turns up from the USA.
BykerBoy
#5 PostAuthor: BykerBoy » Sun May 22, 2016 11:36 am
The number on the barrel is the key number and should be in the range 751-755 on a Z1B. I supply them all the time no problem. The only problems arise with the new pattern switches which are stamped with a Kawasaki correct number but the keys do not in fact match the numbers.
I charge £10 for keys pm me if you want one. If you cant find the number you can send me the switch and I can work out which key number it is.
