vesrah head gasket
ogre
vesrah head gasket
#1 PostAuthor: ogre » Tue May 24, 2016 12:14 pm
hi all goin to be fitting the vesrah head gasket on my z1a does it fit any way round cos the steel rings are round on both sides but one side looks flatter.
cheers
KeithZ1R
#2 PostAuthor: KeithZ1R » Tue May 24, 2016 4:40 pm
the side with the flats on the copper washers goes down im told ...cue derision :lol:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
ogre
#3 PostAuthor: ogre » Tue May 24, 2016 6:10 pm
cheers for that
zpower
#4 PostAuthor: zpower » Tue May 24, 2016 6:23 pm
If you are unsure spray both sides of the gasket with copper gasket and leave to dry prior to fitting.
** Special rates for the Z1OC forum members **
Website design, hosting / domain names.
Computer and Laptop repairs.
PAULJAC47
#5 PostAuthor: PAULJAC47 » Tue May 24, 2016 7:45 pm
KeithZ1R wrote:the side with the flats on the copper washers goes down im told ...cue derision :lol:
Yep slighty domed copper uppermost!
ogre
#6 PostAuthor: ogre » Tue May 24, 2016 8:39 pm
might av been a bit premature between my first post and keithz1r reply cos i think i fitted them the other way round i have put a very thin layer of hylomar on both sides cud it be ok or is it a strip and start again.
#7 PostAuthor: Pigford » Wed May 25, 2016 6:18 am
ogre wrote:might av been a bit premature between my first post and keithz1r reply cos i think i fitted them the other way round i have put a very thin layer of hylomar on both sides cud it be ok or is it a strip and start again.
It's not "end of the world" and should be okay..... just depends how anal you are. Its a gasket and is compressed equally both sides, by similar flat metal surfaces. I'd give it a go and not sweat it :wink: although I'm sure someone will be along to condemn my answer as sh*te :lol:
PS: Hope it's not BLUE hylomar, needs to be high heat resistant.
