Clutch release gubbins in chain casing - can this be fixed?
LTD Project
#1 PostAuthor: LTD Project » Mon Jun 06, 2016 8:19 am
Been having bit bit of a mare trying to get the clutch cable to adjust up correctly and then stay put. It just sort of clicks and then goes all loose..... oooh err missus!
Anyway had a good look today and there appears to be damage to the lug that keeps the cam / ball bearing thingy in place, that the clutch release arm is situated, see photo.
My question is can this just be built up with a bit of ally welding and then re-profiled with dremel? Or will I need a replacement chain casing?
If it can be fixed, does anyone know a good ally welder in the YORK area?
Am so close to getting this right for the Yorkshire Rally in a few weeks.
#2 PostAuthor: z1bman » Mon Jun 06, 2016 8:34 am
#3 PostAuthor: Al » Mon Jun 06, 2016 8:46 am
If its laid out the same as the J; that case on ebay has the forward pivot hole for the gear linkage broken / snapped off/ blocked off. Might be the same situation as you have with the broken stop in youre casing!!
#4 PostAuthor: z1bman » Mon Jun 06, 2016 8:55 am
zorded wrote:If its laid out the same as the J; that case on ebay has the forward pivot hole for the gear linkage broken / snapped off/ blocked off. Might be the same situation as you have with the broken stop in youre casing!!
its the same casing as the ltd. the j model has a tapped hole for the gear lever pivot it a different lever set up on the j model.
here's a new casing for the ltd & its the same as the the used one on e bay
http://www.ebay.co.uk/itm/Genuine-Kawas ... 1085724775
LTD Project
#5 PostAuthor: LTD Project » Mon Jun 06, 2016 8:57 am
Mmmm, there seems to be a few options on ebay.
Any comments on ally welding in YORk area?
#6 PostAuthor: z1bman » Mon Jun 06, 2016 8:59 am
make them an offer of £25 & see what happens :lol: :lol:
LTD Project
#7 PostAuthor: LTD Project » Mon Jun 06, 2016 8:04 pm
Bump..... ?
Users browsing this forum: No registered users and 108 guests
