Does anyone know where can I buy a rotor remover and holding tool from?(to remove the rotor from the crank) Its for a GPz750A3.
Rotor remover
no need to use a holding tool bolt is 18mm x 1.5 thread pitch you can order a bolt from here or your local fasteners you would require one about 60mm long
http://www.ebay.co.uk/itm/M10-M12-M18-E ... ln64kR6SMA
Try checking to see if the rear wheel spindle is the correct thread - it works on the 1100's - I can't remember if it does on 750's or not. That said, a bolt is probably less awkward to use than a gurt long spindle.
Olly
Olly
Lemmy
Lemmy
johny brando
Re: Rotor remover
roosterrs wrote:Does anyone know where can I buy a rotor remover and holding tool from?(to remove the rotor from the crank) Its for a GPz750A3.
I cannot remember exactly what one i used ...maybe both are the same size & pitch ( Top Yolk centre/stem Bolt ) or Wheel spindle..... O yeh & put a largish ball bearing in between the 2 faces first before screwing in .......then pull it up & then give it a good clout with a Nylon headed hammer ...and tighten again & repeat . Cheers.
johny brando
Re: Rotor remover
johny brando wrote:roosterrs wrote:Does anyone know where can I buy a rotor remover and holding tool from?(to remove the rotor from the crank) Its for a GPz750A3.
ALL STOP !!!!! i just noticed GPZ 750 !!! on a 'Z1 Forum' can't help you then don't know anything about them !
