Lockheed M/C seal kit?
Jon
#1 PostAuthor: Jon » Thu Feb 14, 2008 3:22 pm
Hi,
Sure Ive asked this before and some kind person gave me a web link. Like a t**t I lost it tho! :roll: :?? :lol:
Im after a source for a seal kit for a AP Lockheed master cylinder on my Harris. Fed up with the `very` occasional drip leaking and dropping onto my paintwork. :evil: Theres no markings or reference no.s of any kind stamped on the unit itself so no ideas where to start really. :??
Any ideas or should I just pick up a cheap 2nd hand modern one to stick in its place?? :??
#2 PostAuthor: Pigford » Thu Feb 14, 2008 6:13 pm
Jon,
Come on mate, howz about of full shot of the bike.... :twisted: :wink:
Fred
#3 PostAuthor: Fred » Thu Feb 14, 2008 6:19 pm
Jon if you look on the under side of the master cylinder where the banjo bolt fits is there is there one or two lines,i'll need to check but that'll tell you the bore size
Always in front
69 KO 71K1 K6 F2 F1 CB1100F CB900F 74Rickman810 MotoMartinCB950 CB7/11 HarrisCB1100KB 90%Spencer Superbike and a Dax 70
Jumbo
#4 PostAuthor: Jumbo » Thu Feb 14, 2008 7:02 pm
Norman Hyde are quite helpful http://www.normanhyde.co.uk/
also I have emailed AP previously on biketech@apracing.co.uk who also helpful.
LE to JOG on a z900
P.U.M.
#5 PostAuthor: Rich » Thu Feb 14, 2008 7:41 pm
as Fred says it's the number of lines under the cylinder by the banjo bolt hole. I would say go to the AP site and it'll tell you what is available but they've just redone it and it doesn't seem to be up and running for bikes yet :!: If it is leaking from the boot check the bore before buying a seals kit as they usually corrode and wipe out the new seals after a bit.
Jon
#6 PostAuthor: Jon » Fri Feb 15, 2008 10:10 am
Pigford wrote:Jon,
Think everyones bored seeing my bike :?? , but heres a couple of pics from the other day. Got a break in the weather so went for quick spin to one of the local beachs. :lol: Pics of paintwork close up on my webby if yer wanting a look.
Jon
#7 PostAuthor: Jon » Fri Feb 15, 2008 10:26 am
Just checked the cylinder and theres 2 lines scored into cylinder perpendicular to banjo bolt. :?? I`ll see what I can find out from those links. :wink:
Yeah leak is around piston end. With a bit of force I can move end of piston a maximum of 1mm side to side, which compares to one on my ninja which has had nex piston assembly and seals, etc. Dont think its too worn. Most likely original seals tbh.
Previous owners didnt seem to give a toss tbh. Some of the bodges Ive found over the last few years were scary! :shock: :?? Like no fuses, and 20 wires screwed into a knot and selo-taped. :roll: Chain running directly accross swingarm. :roll: Cam cap bolts stripped and glued in place, with one end of exhaust cam free to roam. :roll: Front brakes that did nothing...... literally. :roll: Cracked top yoke. :roll: Battery that rubbed on back wheel! :roll: I could go on for hours. :?? :lol: Hell the bodywork was covered in holographic wrapping paper 1" squares glued on in a pretty pattern. :lol: :lol: :lol: Was cheap tho. :wink:
Jon
#8 PostAuthor: Jon » Fri Feb 15, 2008 5:16 pm
Emailed Norman Hyde picture and no. of lines, etc. See what he says about model as several listed on his site.
Looking at about ?30 all in. Could get a modern m/c of a mate/egay for next to nowt, but think I`ll repair the Lockheed one. Its solid, gives a good feel, and I like the look of it. No plastic anywhere, just a big lump of metal. :lol: Nicer feel to the big 4 pots than my ninja has.
Ed Z1-R
#9 PostAuthor: Ed Z1-R » Fri Feb 15, 2008 8:06 pm
Lawdy a Karloff Kawasaki :shock:
Nice lookin bike :up
#10 PostAuthor: Pigford » Fri Feb 15, 2008 8:36 pm
:twisted: :wink:
Lurve those rear foot pegs...... :shock:
#11 PostAuthor: Rich » Sat Feb 16, 2008 9:04 am
It's the condition of the bore you want to look at. That play is usual, it's the seal that seals not the piston. Brake fluid is hydroscopic and attracts moisture which corrodes the end of the bore causing the seal to leak where it is corroded.
Jon
#12 PostAuthor: Jon » Sat Feb 16, 2008 4:42 pm
Rich wrote:It's the condition of the bore you want to look at. That play is usual, it's the seal that seals not the piston. Brake fluid is hydroscopic and attracts moisture which corrodes the end of the bore causing the seal to leak where it is corroded.
Ok cheers, I`ll strip n check it out fully before ordering a seal kit. :wink:
Jon
#13 PostAuthor: Jon » Sat Feb 16, 2008 4:44 pm
Pigford wrote::twisted: :wink:
Linz did 700-odd mile weekend on the back of Harris the other year. :lol: In the snow too. :?? Damn Orkney rally always seemed to attract the snow. :lol:
Big Fluff
#14 PostAuthor: Big Fluff » Mon Feb 18, 2008 4:39 pm
Jon wrote:Ok cheers, I`ll strip n check it out fully before ordering a seal kit. :wink:
Jon - If you ain't got it sorted yet, pm me as I have just overhauled mine and there are subtle differences.!!!
Complete repair kit is about ?18.
Regs, Will
Jon
#15 PostAuthor: Jon » Tue Feb 19, 2008 3:35 pm
Change of plan. :lol: Got offered a brand new remote reservoir master cylinder with reservoir and lever for ?10 delivered. :wink: Just waiting for mr. postie to bring it. :lol:
Might have a Lockheed mastercylinder going cheap if anyones stuck for one? With polished lever, just requiring seal kit.
