Guys, is there a difference between ZRX1100 and ZRX1200 forks ?
I'm sure I read that the earlier forks can be modified, re-valved maybe ? , whereas the later forks cannot.
Are the wheel spindles and fork bottoms the same ?
ZRX forks
They all use 43mm stanchions.
K-Tech inners cannot be fitted to post 03 bikes as they are basically sealed cartridge forks. Apparently the bottom of the cartridge is peened over so it cannot be removed
The 12's have built in stone shields as part of the dust cover, the 11's don't.
Fork bottoms are similar and will use the same calipers, mudguards will interchange.
Is it just the legs you want ? I should have a spare set of ZRX1200 (02) fork legs somewhere. I also have some 6 pot Tokico calipers that are fitted as standard. (I have fitted Brembo's on my 12).
If they are of any interest, I will fish 'em out and send you some photos.
