I have bought a second hand fuel tap for my Z1B. Which I have replaced the O rings.
When fitted and turned off - fuel is trickling out of the two fuel pipes feeding the carbs.
Is there a sealant I can use to seal the Black plastic sleeve the tap sits in to the body of the tap ?
Kawasaki Z1B fuel tap
wilsonsjw11 wrote:Adrian,
Bin it and buy a genuine Z900 model that come up on ebay.
The replacement sleeves are not available.
Regards
Steve
Sounds like I wasted £70
You would think that there was a sealant / adhesive to refit the Plastic insert with.
Regards
Steve
I am now looking at getting a replacement nylon sleeve made.
