gpz1100b2 fork bushes
dragon95
#1 PostAuthor: dragon95 » Tue Jul 19, 2016 3:52 pm
any one have any , know where to get em ? or what size they would be ?
#2 PostAuthor: z1bman » Tue Jul 19, 2016 4:10 pm
if you mean the top bush under the fork seal part no 44065-1091 cradley have them in stock. the lower bush is not a separate part you have to buy the fork tube
Mr Bump
#3 PostAuthor: Mr Bump » Tue Jul 19, 2016 6:37 pm
I found bottom bushes from an aftermarket supplier a while back. I think it was pyramid parts. Search by dimensions rather than application and you'll find them.
Olly
Lemmy
#4 PostAuthor: Al » Tue Jul 19, 2016 6:48 pm
Bought bottom bushes from a ZX11 1100A Unitrak i think. With a small adjustment (cut a bit off the end if i remember) they fit right in. Three years on track no problems to report.
Tops as has been said should still be available.
dragon95
#5 PostAuthor: dragon95 » Sun Jul 24, 2016 5:20 pm
Just so every one knows, I got a b1 kit off of a place called pyramid parts, had inner and outer bushes, seals and dusts ( dust seals are wrong though )
for 40 quid.. all fitted just fine...
