Petrol t-piece for Mikuni's wanted for between carbs 2-3
KWACKERZ1
#1 PostAuthor: KWACKERZ1 » Fri Aug 19, 2016 4:12 pm
Hi,
My set of 28mm mikuni's have started weeping petrol between carbs 2-3 where the petrol pipe attaches and feeds the two banks of carbs.
Anyone have a good one kicking about or know who may have one on the shelf they are prepared to sell.
(I will try allens if I have no luck on here)
Its part 31 on this diagram.
[/url]http://www.cmsnl.com/kawasaki-kz1000d1-z1r-1978-canada_model15397/partslist/66514.html#results[url]
Or a cheap set of 29mm smoothies would help? :D [/url]
andy c
carbs
#2 PostAuthor: andy c » Fri Aug 19, 2016 4:20 pm
I got pattern ones from Z Power worked a treat .
Re: carbs
#3 PostAuthor: chrisu » Fri Aug 19, 2016 5:01 pm
andy c wrote:I got pattern ones from Z Power worked a treat .
^^^ This - or has been pointed out any favoured Z part supplier.
#4 PostAuthor: z1bman » Fri Aug 19, 2016 7:29 pm
HowieD
#5 PostAuthor: HowieD » Sat Aug 20, 2016 6:01 am
Mr Bump
#6 PostAuthor: Mr Bump » Sat Aug 20, 2016 8:10 am
You can get pukka brass ones with o rings too. Got to be a better bit of engineering than the std ones.
Can't remember the suppliers name just now - ask and I'll find.
Olly
Lemmy
#7 PostAuthor: ZedHead » Sat Aug 20, 2016 9:04 am
If you cant get them from ZPower or Z1 Enterprizes, I have them in stock
http://www.saisei-europe.com/Shop/Produ ... nnector-z1
KeithZ1R
#8 PostAuthor: KeithZ1R » Sat Aug 20, 2016 2:39 pm
in the spirit of sharing info
http://www.nrp-carbs.co.uk/
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Mr Bump
#9 PostAuthor: Mr Bump » Sat Aug 20, 2016 9:30 pm
Nrp carbs - that's the one. Nrp are quite good in my expirience.
Lemmy
#10 PostAuthor: z1bman » Sat Aug 20, 2016 10:01 pm
#11 PostAuthor: Ginger Bear » Sun Aug 21, 2016 6:43 am
I'm sure there might be a member or two willing to make a batch of those. :fou :bla
KWACKERZ1
#12 PostAuthor: KWACKERZ1 » Mon Aug 22, 2016 5:54 pm
Thanks All,
Its great to know they are still available. Going to try the Brass ones for longevity.
#13 PostAuthor: ZedHead » Tue Aug 23, 2016 11:24 am
Ginger Bear wrote:I'm sure there might be a member or two willing to make a batch of those. :fou :bla
Volunteering Steve :D
#14 PostAuthor: Ginger Bear » Tue Aug 23, 2016 1:53 pm
Nope,
Just thought it might be right up Andy Crows or rick Stemps street. :??
