J crank or bottom end
Robw
#1 PostAuthor: Robw » Sat Aug 20, 2016 2:52 pm
Hi all, due to the rotor coming loose, even after torquing it up the end of my crank has been damaged. I am after a good bottom end that I can swap over or a J crank.
Cheers Rob.
#2 PostAuthor: Ginger Bear » Sun Aug 21, 2016 6:39 am
Rob,
Might be worth giving Jack (Londons calling) a shout. He's had Unitrac & 'J' bottom ends from me in the past.
#3 PostAuthor: paul doran » Sun Aug 21, 2016 7:24 pm
if all else fails I have a J crank it looks okay
Robw
#4 PostAuthor: Robw » Mon Aug 22, 2016 9:09 am
Cheers, just been offered a bottom end. So I will have a look at that.
Cheers Rob
