Z1 tank fit a z1000a2 ?
mike_p
#1 PostAuthor: mike_p » Wed Sep 07, 2016 6:40 pm
Will a z1 tank fit on a z1000a2 or are they very different ? I remember hearing a rumour a while back that the z1000 tank has wider mountings ??
#2 PostAuthor: ADRIAN H » Wed Sep 07, 2016 7:48 pm
They are interchangeable as I have a Z1 tank currently on my Z1000.
mike_p
#3 PostAuthor: mike_p » Wed Sep 07, 2016 7:54 pm
That's great......cheers Adrian :D
tlc
#4 PostAuthor: tlc » Thu Sep 08, 2016 4:26 am
Certainly the z900 tank needs the front fixings to be extended as the 1000 tank is narrower at this point.
mike_p
#5 PostAuthor: mike_p » Thu Sep 08, 2016 11:16 am
cheers....I thought I had heard something along those lines w while ago. Is it much different or an easy thing to sort ? I was thinking of buying one of the new repro Z1 tanks from Z Power and putting it on my z1000 as they seem a good price
#6 PostAuthor: ZedHead » Thu Sep 08, 2016 11:47 am
Z1 tank should fit but is very different from Z900 and 1000. Mainly the bottom seam which is inside, closer to the frame on earlier models.
tlc
#7 PostAuthor: tlc » Thu Sep 08, 2016 12:50 pm
It is necessary to extend the lugs which have the round rubbers on.
I used some tube over the original and forced the rubbers on to that.
