Alternator case
Alternator case
#1 PostAuthor: Al » Sat Sep 10, 2016 10:35 am
Looking for a 'cut up' / cut away alternator case. Clearanced' for cornering on the underside only, as in slash cut away below.
It wont have a stator or rotor in it so i think it could be any variant; early, middle, late model as i think they are all the same outer shape!!
Needs to be oil tight as it will be used.
Anyone got anything laying about?
Robw
#2 PostAuthor: Robw » Sat Sep 10, 2016 11:04 am
Could do that mod to my Endurance bike now. Didn't you do the mod before?
Rob
martinz1000r
#3 PostAuthor: martinz1000r » Sat Sep 10, 2016 11:23 am
Deep pockets? A little of Tomforde finest engineering.....
http://www.tomforde-engineering.de/inde ... p&hl=en_GB
At that price you could get the Electrexworld race alternator. They do a version that lets you keep the starter motor now
#4 PostAuthor: Ginger Bear » Sat Sep 10, 2016 12:20 pm
Any good to you Al?
#5 PostAuthor: Al » Sat Sep 10, 2016 7:49 pm
Didnt do mine i helped 'The Terminator' do the one on the Z1100 Ahhh.
That Tom Forde stuff is out of my price range but it really does look the part.
Thanks Steve i have a J cover that looks just like it and another to swop for one if i could find one that has already been done.
#6 PostAuthor: Al » Fri Oct 14, 2016 5:05 pm
Went this way in the end. Not a lot off but its the most you can take and still retain the alternator and rotor inside. Should give a little more leeway and it wont be 'point' contact if it does touch down!
Coose
#7 PostAuthor: Coose » Fri Oct 14, 2016 5:35 pm
That looks grand Al! :D
