Z 1000 Discs
Z 1000 Discs
Anyone out there have a set or individual discs to fit a 1000a1 undrilled if poss, even willing to part with money
pm me if you have cheers
- paul doran
DavidZ1R wrote:paul doran wrote:what date discs do You need
Not sure the date disc, just undrilled front and rear 1977 a, trying to restore one, if that helps Paul
Do you know when your Thou was built David?. If so Paul may have discs he could match to your bike from their Date Stamp.
http://kawtriple.com/mraxl/tips/datecodes/datecodes.htm
Having checked out date codes from what I have to hand, I have a letter U stamped on the shocks, what looks like 01 or 81 7 22 number inside the points cover, and 6 11, and 6 12 stamped on the handlebar controls, nothing on the carbs that I can see, so what should be the date stamp for the discs ?
DavidZ1R wrote:Having checked out date codes from what I have to hand, I have a letter U stamped on the shocks, what looks like 01 or 81 7 22 number inside the points cover, and 6 11, and 6 12 stamped on the handlebar controls, nothing on the carbs that I can see, so what should be the date stamp for the discs ?
Switch blocks are Nov/Dec 76 so presuming they are original to the bike then somewhere around 1V on the discs would do IF possible.
- paul doran
