Z1000 electronic ignition conversion
RussG
#1 PostAuthor: RussG » Tue Sep 20, 2016 6:47 am
Hi, Can anyone suggest a good kit and where to get it from? not sure whether a kit with or without coils as well? Want to replace coils anyway...
#2 PostAuthor: Pigford » Tue Sep 20, 2016 8:03 am
DYNATEK - go for a Dyna S ignition & Dyna Coils :roll:
RALPHARAMA
#3 PostAuthor: RALPHARAMA » Tue Sep 20, 2016 9:48 am
I think Dyna coils are rather over sold and if fitted you MUST make a special bracket for them or they WILL crack and fail. It's not the easiest job in the world either.
Personally I just use original or cheap pattern coils and they work fine.
Dyna S is the bollocks and I can't recommend it highly enough. It's piss easy to fit. The only Achillies heel is that it uses the original mechanical advance/retard so if your springs are dog n ducked on that then you'll need to replace them. I always fit Dyna S to all my Zeds!
Ralph Ferrand
#4 PostAuthor: chrisu » Tue Sep 20, 2016 11:13 am
i need to lie down.
Ralph and I agree on something............. :D
#5 PostAuthor: ZedHead » Tue Sep 20, 2016 12:30 pm
RussG
#6 PostAuthor: RussG » Sat Sep 24, 2016 5:48 am
Thanks guys, Dyna S it is..
#7 PostAuthor: Ultim8pc » Sun Dec 25, 2016 9:29 am
RALPHARAMA wrote:I think Dyna coils are rather over sold and if fitted you MUST make a special bracket for them or they WILL crack and fail.
Do you have more info on this - my recently acquired z900 has Dyna coils and ignition and the coils are not on brackets...
PAULJAC47
#8 PostAuthor: PAULJAC47 » Sun Dec 25, 2016 9:52 am
Used Dyna coils for a few years always just bolted them onto existing mounts,ensuring contacts dont come into contact with the frame,maybe lucky but havn,t had one crack yet..
#9 PostAuthor: Ginger Bear » Sun Dec 25, 2016 9:56 am
Fitted mine like this......
Important thing is to insulate the mounting post, Insulation tape will do, heat shrink is better;
KeithZ1R
#10 PostAuthor: KeithZ1R » Sun Dec 25, 2016 2:01 pm
chrisu wrote:i need to lie down.
you and me both .... however I STILL maintain that the Newtronic Optical system is as stable and reliable If you can find one ( and a dam sight cheaper)
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
