Air-boxes Z900-A4, Z1000-A1?
Garn 1
#1 PostAuthor: Garn 1 » Sun Sep 25, 2016 5:20 am
Trying to tell the differences in the Z900-A4 & Z1000-A1 Air-boxes.
Seem to remember something about height of neck where air-filter fits.
Grooves for cables on side.
air-box cap has provision for two breather tubes!
I need one of these for a Z900-A4. Any help appreciated.
Will either of these fit?
Is it the same filter element for both?
Note the one on left is the same one throughout pics.
RegardZ.
#2 PostAuthor: chrisu » Sun Sep 25, 2016 7:23 am
The one on the left looks like a z1r airbox
Richard Q
#3 PostAuthor: Richard Q » Sun Sep 25, 2016 8:34 am
I have an A4 and the airbox looked like this when I stripped it down. Very similar to the one on the left.
Best to note that there were a lot of things wrong with mine when I bought it, including a lot of Z650 bits, but as far as I am aware, this is the correct airbox.
Richard
Somewhere, over a rainbow, weigh a pie.
1976 KZ900
Garn 1
#4 PostAuthor: Garn 1 » Sun Sep 25, 2016 10:37 am
Thanks guys.
So it looks like the one on the right, in my above pictures is the A4.
This makes sense as (Richard's) A4 air-box has the same vees on either side to allow wiring to pass to the battery area, also, it has the same neck at the air filter hole. Gee!, They are ugly mothers!
RegardZ.
Z1parR
#5 PostAuthor: Z1parR » Sun Sep 25, 2016 11:45 am
As chrisu has said above , the airbox on the left is definitely from a Z1R :up
0172 . Geoff Parr
Garn 1
#6 PostAuthor: Garn 1 » Sun Sep 25, 2016 9:09 pm
Thanks again for the interest,
Z1parR wrote:As chrisu has said above , the airbox on the left is definitely from a Z1R :up
Could Z1R air-boxes be the same as Z1000-A1?
I can only recall playing with either Z900 or Z1000-A1 of this style air-boxes.
I do believe chrisu said it looks like it may be a Z!R?
I wonder if its interchangeable to fit an A4?
RegardZ
Gus
#7 PostAuthor: Gus » Mon Sep 26, 2016 8:17 am
According to Kawasaki/Partzilla
This Kawasaki 11011-1025 BODY,AIR CLEANER is used on these models and components:
1977 KZ1000-A1 KZ1000 AIR CLEANER ('77-'78 A1-A2-A2A)
1977 KZ1000-A1 KZ1000 AIR CLEANER ('79-'80 A3-A3A-A4)
1977 KZ1000-B1 KZ1000 LTD AIR CLEANER ('77-'78 B1-B2)
1978 KZ1000-A2 KZ1000 AIR CLEANER ('77-'78 A1-A2-A2A)
1978 KZ1000-A2 KZ1000 AIR CLEANER ('79-'80 A3-A3A-A4)
1978 KZ1000-A2A KZ1000 AIR CLEANER ('77-'78 A1-A2-A2A)
1978 KZ1000-A2A KZ1000 AIR CLEANER ('79-'80 A3-A3A-A4)
1978 KZ1000-B2 KZ1000 LTD AIR CLEANER ('77-'78 B1-B2)
1978 KZ1000-C1 Police 1000 AIR CLEANER ('78 C1-C1A)
1978 KZ1000-C1A Police 1000 AIR CLEANER ('78 C1-C1A)
1978 KZ1000-D1 Z1R AIR CLEANER ('78 D1)
1978 KZ1000-D1 Z1R AIR CLEANER ('80 D3)
1979 KZ1000-A3 KZ1000 AIR CLEANER ('77-'78 A1-A2-A2A)
1979 KZ1000-A3 KZ1000 AIR CLEANER ('79-'80 A3-A3A-A4)
1979 KZ1000-A3A KZ1000 AIR CLEANER ('77-'78 A1-A2-A2A)
1979 KZ1000-A3A KZ1000 AIR CLEANER ('79-'80 A3-A3A-A4)
1979 KZ1000-B3 KZ1000 LTD AIR CLEANER ('77-'78 B1-B2)
1979 KZ1000-C2 Police 1000 AIR CLEANER ('78 C1-C1A)
1980 KZ1000-A4 KZ1000 AIR CLEANER ('77-'78 A1-A2-A2A)
1980 KZ1000-A4 KZ1000 AIR CLEANER ('79-'80 A3-A3A-A4)
1980 KZ1000-B4 LTD AIR CLEANER ('77-'78 B1-B2)
1980 KZ1000-C3 Police 1000 AIR CLEANER ('78 C1-C1A)
1980 KZ1000-D3 Z1R AIR CLEANER ('78 D1)
1980 KZ1000-D3 Z1R AIR CLEANER ('80 D3)
1981 KZ1000-C4 Police 1000 AIR CLEANER ('78 C1-C1A)
"Set the GRINDER on it"
Garn 1
#8 PostAuthor: Garn 1 » Mon Sep 26, 2016 10:04 pm
Thanks Gus..... That explains it!
Regardz
Steve Cooke
#9 PostAuthor: Steve Cooke » Tue Sep 27, 2016 8:35 pm
The Z1R airbox is quite different from an A1/A2 airbox only the silencer is the same and the A4 airbox is different again, the Z1R box will fit an A1/A2 as I had one fitted to an A1 myself so i would presume it would also fit an A4 with maybe a different support bracket.
Airbox only Part nos.
A4 = 11011-054
A1/A2 = 11011-065
Z1R and others = 11011-1006
#10 PostAuthor: ADRIAN H » Tue Sep 27, 2016 9:15 pm
Z1000 A1/A2 has round tops to suit side panels.
Z1R is squarer.
Garn 1
#11 PostAuthor: Garn 1 » Sat Oct 01, 2016 6:02 am
Thanks Steve & Adrian.
I'm wondering now, after sorting the Z900-A4, what other 1000's was Gus mentioned, will fit the A4? If I forget about the silencer will others fit the A4 , albeit, not a perfect fit!
RegardZ.
